I guess it will be.Elliott for sale?![]()
FTFYElliott for sale cheap?![]()
I regularly order stuff from Aliexpress. Only had one problem where an item did not arrive (courier damaged beyond repair according to the tracking) but Aliexpress did not want to refund.The spindles are on Ebay too for a little more money. Chinese sellers of course. I only mention this as some people don't like buying via Aliexpress,
Fugly tool, but it did the job - it's a keeper
Is the grubscrew supposed to locate in the hole as there seems evidence of tightening further around too. Maybe a copper slug needed.
www.bearing-king.co.uk
Not really. Nowadays, generic bearings are cheap crap.Holy smokes!
Didn't realise bearings were so expensive!
For a bloke messing around in his garage, will some cheaper bearings not be good enough?
I mean, I don't need the bearings to last for 10000 hours of use. I do need a certain degree of accuracy though.
Mate paid through his company so I got these . Had him check spacers in his inspection room as have to be absolutely parallel![]()
7207CTRDULP3 NSK Super Precision Angular Contact Bearing 35x72x17mm (s
High Precision Angular Contact Ball Bearings (standard series) have a line connecting the contact points drawn in the radial direction which is called the contact angle. This contact angle makes the bearing suitable for accommodating radial loads, single direction axial loads and a combination...www.bearing-king.co.uk
