OJCar
- Lothian & Westmorland
I know you have an unfinished project of the roof,exposed to the elements
but does this mean your CU is external to the building?
but does this mean your CU is external to the building?![]()
Gets popcorn and comfy chair ready.
The midges are utter hell today.Slow night up there is it?
What happened to the cartoon before the main feature?Enjoy:
Going to remove the tiles above and get to the wiring that way:
Specially designed to remain rock solid in place while the rest of the box crumples like silver foil……..Those type of knockouts which don't?
You have got a problem with that CU location.
there called knockouts some i called knackupsSpecially designed to remain rock solid in place while the rest of the box crumples like silver foil……..
them i just drilled out with the hole cutter to stop damage to casingThat CU will be fine once youve built the porch your Mrs will ask for about 2 weeks after youve moved the consumer unit!Enjoy:
Have you considered an Insurance Fire ?Yep. Too late in life I heard the phrase "knock down rebuild"![]()
You have to be a Part P sparky
what for doing your own work on your propertyI have a tame one.
nupewhat for doing your own work on your propertynupe
