slim_boy_fat
- Scottish Highlands
Remember half way is half way between low and max, not half filled with oil.However checking it now after a few miles on flat ground, its good and only half way![]()
I fill the canister before I screw it on
It is just about impossible to pre fill the filter on a lot of engines, especially when there is no cannister just a paper filter nestled in the engine with a screw on plastic cap.I don't, never have. Change the oil and filter, give the engine a little run, let cool & top up as necessary. Just keep an eye on it the next day. Nearest I get to pre filling the filter is smearing some new oil on the rubber seal.
You need the build number (For OE number) to tell you which one.Any ideas? 2009, 2L petrol "TS" trim/model. Has aircon, but I imagine they all do..?
Brakes are great fun
New pads needed adjustment with a file to fit.
After spending £400 or so last year for new calliper, I didnt expect it to be siezed in the carrier. The old pads were clearly old ones, not replaced with the calliper and worn like a bananna.
Some marking on the disc but luckily I think I have caught it in time. A couple weeks of driving and the mot guy will never know
How do I clean out the fluid tank, while the fluid itself does not look too bad and was replensished with new. What is all this grey sludge around the filter and sides?
Mot day. Failed. How is £400 for replacement suspension arms?
