Seadog
Save the planet. It's the only one with rum!
- NE London - UK
It's a domestic combi, a Ravenheat. 19 years old, it's not done bad service. I had to replace the diverter diaphragm last year, at which point I soaked the plate heat exchanger in cleaner for a couple of days. That gassed quite a lot. The only other real problem that I've had was intermittent ignition. It turned out to be the ignition module (surprise, surprise). Every pin on both connectors had fractures in the solder. However they seemed perfect to the naked eye. Resoldering with proper lead/tin solder fixed that.Is your boiler used for domestic hot water, heating your home, or both? I suspect that it's rather different from what we're using in our house. I'm planning some upgrades to our boiler to make it more efficient, so that I can procrastinate for a few more years about installing a new system. Our boiler is oil fired and used for heating the house (hot-water baseboard heaters) as well as for domestic/potable hot water. It's 31 years old, but still in reasonably good condition. We just had it inspected and serviced, but I think that if we replace the heat exchanger coil that's used for heating domestic hot water with a more efficient one, we should save a few bucks on our oil bill, and the hot-water recovery time should be shorter...maybe even unlimited shower time.
. I loved that little thing. Getting thin on the ground now and parts even more so.
