waddycall
Yep, though I might be!Same model as mineI use it for checking the speed on my stationary engines, it looks like you're missing the extension shaft?
Bunsens typically use natural gas. Get it plumbed into the houseI need that space for standing in! It's not a lack of floor area that's the issue, it's floor perimeter, it really needs to go against the wall, and there's no more wall left.
That's not all I acquired today though, I also got a crate of vintage lab crap, including a big burner which definitely has too big an orifice to be used with propane...
There's a couple of smaller ones behind it which are just as bad.
Yes,a capable mc from the good old days,@northwest has an improved one even,I’ll get more photos for you when I extract said staircase,covering 50m sq of space!
This will have more power than your previous M18 grinder as I found out and the speed control is always usefulMy second M18 fuel angle grinder from faceplant marketplace with a full box of 50x thin cutting discs for £80.
I have had my other m18 grinder for about 5 years now. When welding cars for MOT I end up changing between flap and cutting discs maybe 20 times a day. This will save some time having flap in one grinder and cutting disc in the other. Also allows for one going down for repair if a bearing wears out. (I had to replace the bearings in my other M18 grinder once before easy DIY job which is why I like these grinders alot)
Sadly no space for another machine.
One of these arrived the other day...
Saves all that tediou farting around trying to drain small engines.
With a bit of soap, dear boy.A drop of warm water and you're all set up for a New Year DIY cleanse!
Saves all that tedious farting around trying to drain small engines.
Buy?![]()
Self propelled might be a good start with all that on board.I will make my own custom welding cart later in 2024. One that can take my MIG, TIG & Plasma cutter + 2no bottles + storage. But no time right now so I ordered a cart from R Tech which will take my Mig and plasma just now and get them off the garage floor.
When I do go to build one I will share ideas on here beforehand.
