Kram
- Sussex
with firepit and plasma, it was going to need some air holes, and it seems I will need to add more and probably bigger.
Got smokey as the bottom filled with ashes.
Sprocket silver soldered. I thought I could cheat using silverflo55 filings from a previous part as I wasnt sure it would wick down to the bottom face. The filings must have had some steel or dirt as they didnt really wet out, some small flames. I had given them plenty of flux paste.
Turned nicely even being intermittent. First cut took it to 10.2mm
Decided that it had not wetted out the face so there was little point in trying to turn the collar off, instead I reheated it.
Fitted compared go old sprocket. Its not a loose fit but has no drive flats yet. New plan is to turn some to braze in.
The mini 4 and 8" bars have a narrower mount and wont fit so test with the echo bar. I'll look for a cheap 8" bar for this but useful to know it fits.
