Misterg
- North Wales
A router guide for cutting binding channels on an acoustic guitar. (The 'bindings' are the decorative strips around the edges of the top/back of a guitar body if you didn't know. A normal bearing guided bit doesn't work well because the angle of the edge isn't 90 degrees, and it varies as you move around the edge of the guitar body.)
Design & CAM in Fusion360
Mostly cut out in several setups on my homemade CNC with the top of the base and the steel shaft done on the mini lathe:
A bit of anodising, trying out my yellow dye:
Some assembly:
In place on the router:
Need to pluck up courage to attack this with it next
Some assembly:
