Part of the problem is likely due to the fact that the water infrastructure is so knackered and leaking that the solution is often pressure zoning. Basically they can't be arsed to fix the leaks so just fit a pressure reducing valve and drop the supply pressure in chunks of the network, so it doesn't leak so bad.
Well...... back in the day we had accountability and common sense - along with men who knew they were men and women who knew they were women.Is this because it’s (presumably) not pressure fed? What an absolute crock of crap, ****** elf and safety, how did people survive prior to it.
from what i gather on here unless you disconnect that washer every time its used you cannot use a direct plumbed in source lunacy of a pen pusher trying to push another regulation into the system that a hose must be disconnected after every useNo, because it is a commercial property*. It is swings and roundabouts - a farmhouse as part of a commercial farm has benefits (tax breaks) in other areas so if you want to enjoy them, you have to obey the rules in other areas.
Donald Trump is in trouble for this - he has classified Mar a Lago as a private club for property tax purposes, but then valued it as a des. res. in order to secure a loan on it.
Being part of a commercial property, any work you do to make it meet the regulations will be a business expense, and thus able to be offset against your tax (even the washing machine itself could be seen as a business expense).
* it is a little outside this discussion but I understand there is a distinction between 'residential' farms and 'commercial' farms. I wonder what the water people have to say about a residential farm.
if you do get pushed down them swap to rainwater collection to a tank whilst your not bound by the farm rules of collecting contaminated water from the roof 2 ibc tanks full of water will provide enough water pressure to run the washer put them at a height and you gain further water pressureyes there are tax breaks with farm houses…..inheritance tax being one of them.
Ill let you know what they say if they come here…..regarding commercial vs residential….not sure where will fit as we dont claim farm payments, but run a business….. does this mean holiday lets and ex farm workers properties now let on a short hold tenancy will need to comply to these daft rules.
looks like the twin tub washer will be coming back. Or there will be big demand for bore holes.
Well...... back in the day we had accountability and common sense - along with men who knew they were men and women who knew they were women.![]()
Abstraction licences are impossible to get around here. You can have an unlicensed 20m2 a day bore but anything larger is a no.I'm surprised there are so many farms about without their own supply. Water rates and the poor peak flow rate means most around here have bore holes, lakes or wells to draw from.
If they wanted to keep to mains, a relatively cost efficient way to improve flow during times of high demand is to use the mains to fill a buffer tank (with a hole in below the fill point) and boost it around the network.
That's 20,000 ltrs per day. Got to have some big undies and really bad IBS to need much.Abstraction licences are impossible to get around here. You can have an unlicensed 20m2 a day bore but anything larger is a no.
Cant see it been an issue for us, we have a spring on the hill, on my land behind our house, it didn't dry up year before last during that hot summer, though not really enough to supply 3 modern properties. Id not fit a water tower, as it would be an eyesore in a national park. Id just gowith a nupress type tank, supplied from a bore hole if worst comes to worst. Were only about 100 feet above the river at the bottom of the front field, so it wouldnt need to be too deep. Next door has one.from what i gather on here unless you disconnect that washer every time its used you cannot use a direct plumbed in source lunacy of a pen pusher trying to push another regulation into the system that a hose must be disconnected after every use
the alternative is simple build yourself a high water tank and fill that to feed a washing machine as your within the rules just make sure its either a room access to it for easy inspection a high water tank within the buildings will have its own rules on covering
water tanks are used in low lands to gain pressure the same system that the water board uses
since the water board is enforcing it, farmers then have a right to submit planning permission under special grounds the submitting of a water tower build or water tank build on there property to feed the nescessary appliances for cleaning purposes
as that is 2 grounds of application for aproval
if refused you have the right of apeal due to the water board enforcing a tank use within the property which is ommiting circumstances
Buy a poss tub fill it with hose.I did ask one of the inspectors. What if I take the overalls home and wash them there. He said no problem machines in a domestic house are not covered the the regulations.
I think it’s the same principle as an eductor - a device usually found on ships that uses the flow of water (usually from a fire main) to pump water out of compartments.The main causes of back syphonage due to a negative pressure in the main is something like a major leak causing the main to act in effect like a syphon or someone Pumping the water from the main. Not normally allowed to pump the water main unless flowrate is very low as a normal water user, I'd need to go check the byelaws to get the flowrate but it's a miniscule flowrate. Ive only ever done it when designing pumping station for water utilities in past. Where that's done there's pressure transducers on the system to ensure it doesn't impact the upstream main. The only other time I know of where you can get a negative pressure in the main is if the fire brigade need to pump water from a hydrant or several hydrants and accidentally pull a negative pressure in the.main.
Thats about right, but the root of the issue is the infrastructure isnt up to the job, poorly maintained and under funded, because share holder Divis are more important…..this wont really change regardless of what hoops farmers etc are forced to jump through!I think it’s the same principle as an eductor - a device usually found on ships that uses the flow of water (usually from a fire main) to pump water out of compartments.
They can shift huge volumes of water, so it’s easy to see how in principle they could easily syphon stuff back into the water main.
I guess even if they wouldn’t be anywhere near as efficient as a properly designed eductor I imagine if the flow paths and conditions were right
How Eductors & Ejectors work - Principle of Operation
Morris Ejector Technologies, Ltd - Venturi Products & Solutions, The principle of how venturi device works, be it an Eductor, Ejector, Heater or Desuperheater, all are based on the Bernoulli theorem and Venturi principle.www.morrisejectors.com
And every tank you fit needs a massive slot cut through the side of it.View attachment 429904View attachment 429905
Outside taps need a double check valve built in or in supply pipe. But they cannot have a hose or even a hose connector unless it's fitted with a DC pipe interrupter.
