The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Not at all, I have hemp rope for that.To hang myself?
Doubt you would be able to do that over here the fluorescent brigade with the clipboards would have 40 fits!Engine change finished, good four days work from start to finish.
This bit was fun, engine attached to forks, not breaking windows or bending balconies.
Finally got these one back to life.
It was badly repaired by someone else who destroyed power section which caused several additional damage.
Unfortunately they used very rare Mosfets which are hard to find.
Anyway.
Now it’s working again.
Hi,Very cool a German made machine.
Is it 3 phase?
Have you got any pics of the innards just curious as I seen one similar for cheap locally which had let the magic smoke out. I am tempted to take it home and see if I can put the smoke back into it.
Not today, but several years ago. Could be of interest though.
Fireplace outfit that I used to help out occasionally with tech stuff. The did marble surrounds, woodstoves etc I occasionally built non standard wood stoves for them, like a six sided one for a restaurant.
They got into underfloor electric heating, using kit from Holland or scandi.
Anyway, a big living room had been wired and the floor laid with very expensive tiles. The system tripped out to earth and hair was being pulled at digging it up, around 80 sq mt. so a lot of money.
Talking to the factory, they had a bit of kit to find the fault and sort it, so sent it out. Interesting box arrived. The cabling was +ve & -ve twin and the idea was that the machine ran 4,000 volts down the wire and then at the damaged point, it would carbonised the insulation. It then sent a low pulse down the line and one used a detector to follow the the line until the pulse stopped, which would be the point were the cable shorted.
I read the book carefully and we tripped out to the house (a new build and very smart..) and got to work. Owner was there too....
Ran the system with the high voltage (carefully!) and checked the pulse system. Seemed to function, so started with the detector and phones.
After going backwards and forewards over most of the floor, the pulse stopped. Confirmed it with a few passes, then chalked a cross and told the waiting bloke with the tools to dig there. He bust up the tile and chiselled the concrete. Few minutes later a charred cable appeared within an inch of my cross. The atmosphere of relief was pretty solid and the owner extremely impressed. The box had come with repair kits and I fitted one, potting the result, then tested the system, all OK.
I also commented that likely, from the look of it, someone had leaned on a spade and cut the insulation.
They bought their own tester box and applied new MO. Systems were tested after laying and again after concrete laid. After that, any fault was charged to the builder.
I could do with one of those here at the bungalow in South Wales , we had a lightening strike several years back, , The insurers paid for a new under floor tiles wet room trace heat cable system , three years later it gave up on us . I do have a high impedance signal generator and a listening coil device but I couldn't locate the break or breaks caused by a bad installation of the electrician or tiler. The bulb thermostat in a copper capped soldered up pipe appears to be OK . The new with the new floor wall thermostat appears to be OK too .
great job you made of that MatIt doesn't look like it's welded, but it you zoom in, the bottom inch on the left isn't as shiny as the rest, cut it tacked it, with arc stainless rods, then decided to tig it.
Had completely the wrong settings dialled in, cooked a hole in it.
Chopped a bit of same size diameter pipe, from dead balcony, slit it, hammered it inside, built back up the hole, welded the joint, looked a dogs dinner, got my finger (B&D) file going, cleaned off raised puddles, and then 800 grit to attempt to polish it up.
You have to look for it, it's fairly tidy, I am no tig pro.
Thank you, even my wife said it looks good, I've been asking my company for years to send me on tig training course.great job you made of that Mat![]()
you need to be asking them for a pay rise looking at that repairThank you, even my wife said it looks good, I've been asking my company for years to send me on course.
