You're meant to around the corners!thread revival....
yesterday i broke
✂️ oops
30 seconds · Clipped by RX8Jim · Original video "Perranporth trackday 15102023 session3" by RX8Jimyoutube.com
my race car.....![]()
Last time I had to abandon a brake job half way through and wait for new parts to arrive, this trick worked.The brake pipe at the back of my car, while putting the trailing arm back in after replacing the bush. It's a pain in the neck, and if it drops all the fluid out overnight it's a real pain to bleed it all.
Whack a self tapper in it overnight.
Not a good idea to use dregs long term as it's hydroscopic and will possibly give problems .Thanks for the thoughts, by the time I posted on here I'd already left the car for the night. I thought I'd got away with it as there wasn't a massive amount of fluid in the tub this morning, but after bleeding the one I'd disturbed there's still no pedal pressure, so I expect the next thing is to bleed the master cylinder and then try again - I ran out of fluid this afternoon after marshalling all the end-of-bottle bit I had. The back end of the pipe has been looking a little rusty for a few years, so I expect it was just too fragile to be moved around. It's all back together now, with a new section of pipe and I got to try out the on-car pipe flaring tool that I had from @JOEPRO back in March - I don't recall why I bought it, but I expect it was for this sort of situation. I took the opportunity to fix a few other things that I couldn't have done while keeping the brake line in tact.
Why wd40? Better off dry imho, in out in out...I cut a solid U shaped round bar door handle up to get a bit of round aluminium bar stock . it cut well on the bi-metallic band saw, popped it in the lathe noticed it was not quite as straight along the length ( 95 mm ) as I'd hoped . Never mind I can turn it round for what I want .
I faced off the end and put a brand new centre point drill in the tailstock chuck , set it to be almost ready to drill , tightened the tail stock , set the lathe going at about 500 rpm slowly advance the drill into the aluminium gavre it a squirt of WD40 eased in in about five mm when " Ping" grrrundle grind etc etc. the drill tip broke in the stock . Stopped the lathe looked at the center drill , it had shattered right fron the tip of the drill point to about 12 mm along the drill body .
This is the second center drill I've ever broken but it wasn't like this one . The first was in a hot forged high tensile steel bolt head .. full of stresses ,
The pump up pressure bleeders are a joy to use. I was looking for cars to do a fluid change on after I got mineBought some new brake fluid yesterday (first use of my Halfords Trade Card) and bled the master cylinder and opposite corner to the broken pipe, and I have a brake pedal again. Remains to be seen whether it's good enough - I hadn't driven the car since Saturday so I can't really say whether it's the same as before, slightly worse or slightly better. I may call the main agent and see if they do a decent price on a brake fluid change, or I have been offered the loan of a pressurised brake fluid filler thing (like a garden spray, I guess one up from the ones that fix onto a spare tyre) if the ABS unit needs to be cycled.
(In isolation this isn't a "what I broke today", just an update of the thing I broke the other day, further up the thread).
It did wear off quite quicklyAre you mad woman?
but compared to pedal up, pedal down.... So much easierYou have to ask?Are you mad woman?
