Seadog
Save the planet. It's the only one with rum!
- NE London - UK
I see that you worked out which way to fit the fixed jawView attachment 417832
15kg of rust. But is a nice shape.
I will call a Supplier of ale at my local.
Clean, apply heat and oil and they will be free!!!!!!!!!!!!!!!!!!!!
Not a blood chance.
Each one is a different thread form, same size, but different.
5 Spanners needed on that side alone.
Made worse, they were not studs or bolts. Threaded rivets!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That is rust and grease.
Out of the citric acid, plus a random clamp.
They are castings, so the need a good drying out. This puts enough heat in to draw the water out.
This shows the different metals used.
Few more coats of Hot wax and oil needed.
It is still a Bar Steward.
