hermetic
does the motor make any noise at all, it is very unlikely to be totally goosed unless it is burnt out, does it have a centrifugal switch? is it open circuit when it should be closed for starting? have you checked the socket you are using with another appliance to make sure it is live? the motor has a start and a run winding, they will be marked A1 and A2 for the run, and Z1 and Z2 for the start winding, or maybe U1/2 and V1/2 whatever, you should be able to measure continuity between 1 and 2 on the same winding.
