Yes the beginning of flex is similar as dictated by Young’s modulus but better materials then hold on . A good example would be a mild steel pry bar compared to carbon steelYoungs Modulus is your indication of resistance to bending - and all steels, including stainless are pretty similar.
Young’s Modulus of Steel (GPa, ksi) — Chart by Grade, Definition & Temperature Effect
Young’s modulus of steel: typical range 190–215 GPa (27,500–31,200 ksi). Tables by grade + temperature effect.amesweb.info
If the bar is excessively bug gered from previous owners abuse, I'd have a slight concern of the state of the rest of it - at the very least, a worry over the parallelism of the jaws. I'd be peering at the neck for signs of cracks . . .
It seems the statement "every type and grade of steel will have identical behaviour under bending stress" is misleading. Stronger steels deflect less under identical bending stress.
In my mind the matter has been answered concerning a vice handle using 303 stainless steel. As pressbrake1 mentions regarding the choice of steel material for a pry bar. What is your view on the use of mild steel for this tool when it has been suggested "every type and grade of steel will have identical behaviour under bending stress"?Yes but in this specific example where you are using it as a vice handle, the difference is only a few percent. Like I have said (and @brightspark) once you exceed the elastic limit, all bets are off because you are exceeding your design parameter for the vice.
It would be hilarious to use a spring steel handle on a vice though I'd probably want to have my dentist on speed dial before I tried it!![]()
It isn't a few percent - it's several hundred percent, no matter what the application.Yes but in this specific example where you are using it as a vice handle, the difference is only a few percent.
How much weight do you think it's sensible to put on a vice handle?
50kg on a 300mm long, 17mm diameter handle gives a maximum stress of about 310MPa
Cold drawn mild steel has a yield stress of about 350 MPa = job's a good 'un.
Hot rolled mild steel has a yield stress of 200 - 250 MPa = bent handle.
303 stainless has a yield stress of >400 MPa*, so should be OK.
(*Presumably 'as drawn' but not stated - many stainless grades have very low yield stresses (~~200 MPa ) in the annealed condition)
Heat treatable steels, when quenched and tempered can easily exceed 1500MPa yield stress - 580% higher than hot rolled mild. (But don't get me started on toughness.)
Below about 200MPa, I agree that the different grades / types will have almost indistinguishable stiffness (deflection for a given load) which I think was the gist of the original comment.
To be sure of ending up with a vice handle (or pry bar) that doesn't bend, however, one needs to check that the yield stress isn't exceeded in a 'reasonable' usage scenario - pretty much any steel that isn't hot formed or annealed would survive the vice handle case above.
FFS. I hope you know how drawn out this thread is about to become after that post.![]()
It is sad that the term "FFS" needs to be provided by a contributor.
ive pressed a few bearings out and in with my 6 inch vice and pulled as hard as i can without bending the bar . all i can say is theres some animals out there that arnt fit to be using tools of any description![]()
Mattf: please confirm if this some sort of threat? Site Moderator please intervene and let me have your views.See if you're still saying that a few pages from now.
It seems a simple question I have asked. Please reply.Are you serious?
