mangocrazy
Italian V-twin nutjob
- Sheffield, UK
I'm presently half way through restoring an old Record 111P vice. but the problem I have is that the tommy bar it came with was bent and damaged beyond further use and I need to make a new one for it. As far as I can tell I will need 11/16" steel rod, of a length approximately 13" / 300mm. My concern is, what grade of steel should I use for this? Mild steel would be cheapest and easiest to source, but would it stand up to hard use? Should I be looking at silver steel or some higher quality steel for this? The other complication is that I will need to get some end caps made and these will need fixing to the bar, either by bonding, welding or screwing on. If I go with welding, I presume that will restrict my choice of steel. Do I go with something 'hard' and possibly brittle or softer and more ductile?
