States 75mm x 457mm on the box (3" x 10"). I've got a few of that size a neighbour gave me awhile ago.Those belt sanders aren't too bad. The belts are a bit ****e though. The joint is lumpy. What size belts do they take? ............................................
Think i have about 6 boxes of them (a lot of belts) surplus hereStates 75mm x 457mm on the box (3" x 10"). I've got a few of that size a neighbour gave me awhile ago.
If you need somewhere to dump all that old racking youre more than welcome to drop it at mine!Not today, I acquired a tilt bed trailer. A couple of feet longer than my other one, a mate had this festering in his field and decided I would have more use for it. Needs the brakes and wiring sorted out, havent checked the hydraulics on the tilt yet.
Bob
Thats teasing! I assume it must all be located down Kent way?There's 'enough'![]()
Yep there is a bit here , if you need some pm meThats teasing! I assume it must all be located down Kent way?
I'm surprised you've not got all that filled yet..Yep there is a bit here , if you need some pm me
View attachment 410734View attachment 410735
View attachment 410737View attachment 410738
If it's the 75 x 457 it's the same size as the small makita belt sanders , but they also did one that looks identical but takes a longer belt .Those belt sanders aren't too bad. The belts are a bit ****e though. The joint is lumpy. What size belts do they take? Could do with trying a better quality belt on mine. It's been sat in a cupboard since I moved here.
I'd be interested in a few if want shot of some ....Think i have about 6 boxes of them (a lot of belts) surplus here![]()
I will dig them out and see whats there mate...no good to me as i don't have a sander they fitIf it's the 75 x 457 it's the same size as the small makita belt sanders , but they also did one that looks identical but takes a longer belt .
I've the makita and a lidl one it's not a bad machine for money I like the flip up cover on the front roller and the brackets for mounting it upside down . I generally grab any cheap belts I see in 75 x 457.
there is a bit here
Make some fly-screens for house doors and windows keep all those nasty bugs out in summer.Scored a roll of scaffold netting. 2m wide and ?m long. Don't know what I'll use it for yet...
No good for garden netting, it wouldn't let pollinators like bees through...
You're a jammy bloody git you know that.Not today, I acquired a tilt bed trailer. A couple of feet longer than my other one, a mate had this festering in his field and decided I would have more use for it. Needs the brakes and wiring sorted out, havent checked the hydraulics on the tilt yet.
Bob
