julianthegypsy
- Cirencester
Beautiful job.
The blue flame of Sulphur handle fixing.
but as it's army it's meant to be painted matt green i have to same pickaxe in the shedView attachment 402226
This British Army WW2 Pick Axe came my way.
The issues are:
Jammed head.
Deformed points.
Rough finish and splinters on the handle.
Plus it was not WW2.
The trader has refunded me 50% of what I paid for it.
It took some head beating to shift the head. There was a serries of burrs in the hole.
Here the handle has been worked over with a cabinet scraper.
The head was cleaned up, the burrs removed.
The tips were dressed to a point, the heated to cherry red. Diped into cold salted water to harden them.
Then tempered to a blue finish.
When it was still hot a wax/oil mix was applied.
Handle was finished with a glass scraper, then french polish applied. No sanding sealer, as you want a textured finish for grip.
The fit is now correct.
Finished.
Next time I will try to remember to do so.You ought do a proper, readily findable write-up on that process, for those of us with crappy memories.![]()
There is no peace time regulation to say they have to be green.but as it's army it's meant to be painted matt green i have to same pickaxe in the shed
also the same battery charger thats still in use![]()
Is this site any good for the wiring diagram ?View attachment 402236
Another Meter in a box.
.View attachment 402238
Sifam Moving Coil meter.
I was told it was not working.
I can't work out why.
I am seaking a drwaing to re wire it.
Untill then.
This handy tool is fantastic for getting into the edges to cut back the tired polish. A cabinet scraper does the rest.
The lower parts can be seen on the lid, gentle working will have it level.
Cleaning some of the fixings.
GX390Oops, my generator threw a wobbler.
No other damage luckily, it should be an easy repair .
We did the bottom seal on the VW LT35 the small pipe on the plastic housing broke off so i drilled a hole in what was left then used super glue to fix in a bit of 8mm copper pipe and added some baking soda and glue as a shoulder to help it. View attachment 402385View attachment 402386
I would have done but i could not find an olive, i have also used a yorkshire coupler if itas a bad fitHello, I've done similar repairs on my DS, I always solder an olive near the end of the copper pipe to stop the hose popping off.
Looks as new again, nice.A long day! Bearing replacement and shaft repair on a piece of bakery equipment
View attachment 402528 View attachment 402529 View attachment 402530 View attachment 402531 View attachment 402532 View attachment 402533
