steveo3002
yeah he must be a beast , he lifts these golf boxes like theyre nothing , i can barley drag it along the floor
I did the transfer box on the 110 like that. Not my finest moment and I paid for it laterTotally off topic, but sort of relevant to lifting gearbox's and changing clutches laying on your back on your drive.
If you haven't already, check out Kevin Williams on the you tube. Just bench presses the box in and out, with the occasional onto the belly and yoik it up from there. I could barely lift the box out of my vivaro, let alone get it into position on my own, straight in for young Kev though, no messing about.
We all make mistakes, can happen to anyone, but as you say, I think you will have noticed that, but ..........
A few years ago we replaced the clutch on a friends Sierra. Needed to go out in the afternoon so got the thing on ramps at set to it. Took about an hour.
Got it all back together and sat on the garden wall with a celebratory cup of tea before getting it off the ramps.
Only to notice both the new and old release bearing in the box ..........
Not judder but we had similar on Mrs79’s motocross bike front brake. She had put braided stainless hose on, same bore, braid supposed to restrict expansion so better braking etc etc.wasnt sure wether to post or not
i went to the car earlier in the week to move it into a place i can strip it , hyd clutch pedal was on the floor , i swapped a spare hose over that i had and rebled it , tried it again , id say the judder is half or better , almost at a level where you could believe a bit of use might settle it
so i havent stripped it further , ive ordered a new hyd line and will see how it feels with that
not really sure how /why that exaggerated the judder
yeah i used to want all that on the cars , then had a braided brake line burst on the mot rolllers , when you think about braided ones look great until the day they fail , at least you can spot a perished rubber one and maybe it will bulge before failing , i wont run em nowNot judder but we had similar on Mrs79’s motocross bike front brake. She had put braided stainless hose on, same bore, braid supposed to restrict expansion so better braking etc etc.
Could not get a decent brake on it.
Gave up. Refitted old KTM ones. Good as new. Still no idea why.
Posted because you’re not the only one!!
Inside the master cylinder dust cover or the slavebeen back to the car and the pedal has gone soggy again ...so must want some hyd parts too , nothing appears to be leaking though
Might be restricting flow back from the slave, so releasing the clutch slower than ideal?wasnt sure wether to post or not
yes this one did from new , struggled to get oem style ones over the years so its had braided , managed to get a oem style one, might be slightly bigger diameter , need to look at that todayDidn't some cars have a coiled hard line for tthe clutch hydraulics to reduce judder.
