colnerov
- Nr Gatwick UK
There you go Paul
Already in post# 12.
There you go Paul
IVA is not the issue but it becomes a problem. If you read the (twice!) Posted newsletter article it is clear that DVLA have moved the goalposts with regard to the acceptable evidence for registration of vehicles that have no registration for what ever reason. They have also decided that any repair or modification no matter how trivial will result in the application being rejected as the vehicle is "modified". The only avenue available from there is BIVA which 99.9% have no chance of passing.I’m not sure that IVA is the issue, is it not more to do with the classification of “modified vehicles”? And once termed as such, then the IVA kicks in?
If you glance at most historic cars, but not all I grant you, they will, over the years had various modifications to make them better in one way or another (maybe worse as well). So the need is out there, and to my knowledge it generally hasn’t been something that needed fixing - so why the change?
I've never seen anything about MOT testers having to see the welding work, but I'm happy to be proven wrong if you have a link. I always assumed this is just over enthusiastic MOT testers.I also see alot of let's call them "low end" cars and vans on the road with really rusty patches on the cills!
This is because they obviously failed MOT for rust and had to present them back with bare steel and welds for inspection. Then they just drive them on months later rusting away without having painted them over to protect them![]()
According to ChatGPT welding work does not have to be inspected in MOT test:I also see alot of let's call them "low end" cars and vans on the road with really rusty patches on the cills!
No, MOT (Ministry of Transport) inspections do not involve evaluating welding work directly. However, if a vehicle has been welded as part of its repair or maintenance, the welding must be of a suitable quality and standard to ensure the vehicle is safe to drive. The MOT test will include an inspection of the vehicle's structure and bodywork to ensure it is free from excessive corrosion or damage, and any areas that have been welded will be assessed to ensure they meet the required standards.
Thats ok up untill 2021 ish. though.According to ChatGPT welding work does not have to be inspected in MOT test:
He’s in NI. I think it’s different there.According to ChatGPT welding work does not have to be inspected in MOT test:
Well the question posed to ChatGPT by @Stupoty was about laws on welding. That's different than asking about what welding will pass an MOT.I've read the whole post but iam still none the wiser. Does this mean that any welding on a vehicle will fail an MOT ?
Does that mean you can’t build any watercraft at all now then unless it’s type approved?If welding isnt allowed it would render 99 of historic cars fit for scrap. It strikes me that its legislating anything they dont like off the road. Doesnt matter that the classic & modified car/ vehicle world is a big industry. It isnt seen a PC any more as it isnt green, therefore it must be gotten rid of.
It reminds me very much of 1998 when the govment enacted the Recreational Craft directive for boats. It was already highly advanced when a crowd of us wooden boatbuilders found out about it at the wooden boat show & formed the wooden boatbuilders trade association. They managed with others to water it down slightly.
But the effect was overnight the British kit & home built boatbuilding industry was totally decimated overnight. A whole industry destroyed so big business could profit. No increase in safety just reams of pointless paperwork.
A few years ago i was at the point of getting a rowing boat i had built through the RCD, I needed no less than 4 iso standards at £150 each, then the over reaching application document £450, The iso documents i managed to acquire free from a mate who worked at lloyds the stack was 2" thick.
I pulled the plug on the project.
If crap like this comes to the car world it is finished.
Me either.I've read the whole post but iam still none the wiser. Does this mean that any welding on a vehicle will fail an MOT ?
Me either.
The repair standards for MOT allow it and that’s what the MOT people use.
DVSA publishes that document.
I’m at a loss as to what the DVLA have to do with it.
I’ve never heard of anyone getting a failure because of welding. Even **** welding is a possibility of a pass as it’s ‘minimum standard’ for an MOT pass.
And what is chat gpt?
Doing that boron stuff is alright if you gas weld it though. If you cold mig/tig weld it it just cracks.
Mainly just A pillars and subframes commonly.
Aye the molecules don't flow as fast towards more localised heat that mig/tig gives. They're happy in a warm state over a larger area... Sort of... There's stuff out there that can explain it far better than my layman's terms. But basically that.Is that because with gas you heat up a greater area?
Somebody posted the relevant bit of the MoT tester's manual up there ^ , I welded up the sill on my daughter's 106 only a few weeks ago after it failed the first time round and it was accepted without question.
I'd go along with the other advice above though, make a good job of it before presenting it the first time and nobody will be any the wiser.
