You sure it's me? I have seen replies to me in threads I have not even posted in. I just did not have time to check it out back then...Don't know whats going on but your quote is from ukracer but has my name on it & links to my safecracker thread!![]()
I see what you mean now...Don't know whats going on but your quote is from ukracer but has my name on it & links to my safecracker thread!![]()
It comes with 3 different expanding adaptors but I've gotten him to detail one up which should fit exactly, the 23 spline Mondeo clutch:
I have to a ask: 23 splines and four regularly-spaced slots for expansion?
It will have one slot either at the root or tip of a spline and the rest will have no relationship to a spline. That is the beauty of 3D modelling: with thought the slots could be unequally spaced.
For what the alignment tool has to do, there is no benefit to it being splined.
Broomhandle wouldn't work on a spigotless gearboxA case of can we, not should we!
He could just as easily have printed a broom handle in woodgrain PLA and wrapped insulating tape around it!![]()
Broomhandle wouldn't work on a spigotless gearbox![]()
Too good...
Here's one my 3D printer made. Not me, I nicked it off Thingiverse...
it is a scan from a genuine artefact and yes I made it for a child. But I am going to give the other one to a five year old who is obsessed with dinosaurs currently.
Having asid that, I had a devil of a job getting it to print and then getting the print out of the support structure. Spent a pleasant morning whittling away at it, you can see some of the detritus above.
The finish is spectacular. Almost like polished bone!
But it's a smallish model, only 6 inches long. So I am right now printing another, bigger version closer to 10 inches.
It took me all morning to get the print started due to complications with the irregular base and the requirement to somehow not lose all those teeth...
I think you should now bury it in a 10:1 sand cement mix and give it to them with a tooth pick.
It is already entombed in support. All the green is support material.
Not a bad idea though.
