Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
Have you ever changed the clutch cable on a Renault 19 16valve?
Have you ever tried to change the heater matrix or wiper spindles on a Scimitar? Rumour has it that Reliant started with those items and then built the car around them!
I recently mounted a wall air reel. Now I want to put one of my compressors- a 100L one in my attic loft
Sketchy? Yes.
Will make an aluminium wheel holder to secure it.
Starting to run a copper air pipe to fall now towards water tap outlet and water sep on wall as recommended on here
Another vote for auto drain but if you’re concerned about it failing then a remote drain would do well.I recently mounted a wall air reel. Now I want to put one of my compressors- a 100L one in my attic loft
Sketchy? Yes.
. . . sure enough get plug out (stupid little 16 mm hex) and it's clogged to death with soft carbon. Run it through the sand blaster - now it has a lovely clean insulator - blow the sand out with an airline and re-install with just a trace of oil on the threads. Starts first crank - drives about fine.
. . . . conclusion - started on choke - remained on choke - choked to death - gentle word in gardeners ear required !
Poor sod probably doesn't know what a choke is, they don't teach kids engines anymore remember.
Yes, that’s true. If the output shaft hadn’t been off kilter I wouldn’t have bothered to re-bore the holes, although I consider the porous sintered Oilite bearings to be an improvement, as they can retain a good deal of oil and can go for longer intervals between oiling. The other shaft (input shaft) doesn't have any bushings in the casting (just the steel shaft against cast iron), but it has two lubrication ports in the casting, making it more convenient to keep lubricated than the output shaft.Lubricated cast iron and steel actually make good bearings - an enormous number of which are used in one of our current machines all over the world, at quite high speed too.
