hotponyshoes
- Somerset. Uk
Dumb questions time (it'll become obvious I know very little about plasma cutters).
1. Pilot Arc. This is a good feature & means you can light the arc flame without needing it to touch/scratch it on the metal you want to cut, yes?
2. If the torch can be lit without contact & in free air - does this mean that you could use it to say heat up seized nuts to free them (like you would with oxy or MAPP gas)?
3. If you have a compressor (I have 2, one being a portable 100L belt-drive), then the lack of an on-board air compressor doesn't create any problems or significant negatives?
4. Can you use a PC to cut out corroded metal on the vehicle realistically & practically, & without torching the thing?
Ta muchly.
G.
1. Yes, main benifit is you can cut through painted metal, also good for weldmesh etc.
2. No, the flame is still the same intensity so will just cut the nut/bolt up rather than heat it. Look at an induction heater for that..
3. No. Inbuilt compressor makes the unit easier to move, quicker to set up but probably comes with a decrease in proformance? It's generally reccomended to use clean dry air for a plasma so you might want to account for that in the budget but I can't imagine the lidl in-built version has much in the way of air drying in it?
4. Yes, much safer than a gas torch, main risk is burning through one panel into another behind. If you had 2 cars and wanted to transplant a panel from one to another the plasma might not be the best/only tool to use on both but for quickly removing a panel from a donor car you can just whip around it oversize with the plasma then put it on the bench to trim/tidy it up using more controlled methods.
