gaz1
- westyorkshire
yours is set right so the coment wasnt for you it was for the poster saying the air is best taken from inside of the building then goes through the burner then outThe cool fresh air is pipe directly into the inlet of the heat exchanger, if you notice in my pictures there is about 400 mm of ribbed 100 mm ID aluminium duct and stainless tube for it to pass along before it enters the heat exchanger , so I'm not hung up with the idea of a few lost joules of heat .
The mancupboard is well toasty warm at 15 oC on setting H 1 , having it on H 6 would be way too hot for me .
which is not a good way for any stove if your spray painting, wood stoves being the worst as they take more air from within the building to be burnt and sent up the chimney
