Olderisbetter
- Wolverhampton
It looks ok but the the corners started lifting, i will repeat tomorrow after cleaning the bed and giving it a IPA wipe.What does the first layer look like, squish wise?
Don't use IPA. It is what was causing my loss of adhesion because it was leaving something behind.It looks ok but the the corners started lifting, i will repeat tomorrow after cleaning the bed and giving it a IPA wipe.
If you are lucky it will have Marlin firmware.It looks ok but the the corners started lifting, i will repeat tomorrow after cleaning the bed and giving it a IPA wipe.
I use soap and water.Don't use IPA. It is what was causing my loss of adhesion because it was leaving something behind.
Original 3DLAC was.Apparently 3DLAC is merely hairspray without perfumes.
Anything really, acrylic or polyurethane car or modelshop lacquers are fine, PET-G's really tolerant of chemicals.
That only mainly helps with tramming - that the bed is the same distance from the nozzle across its whole surface - but it’s not for setting the Gap. You set it by looking at the first layer and how the traces join.Yes i used an A4 printer sheet
Surrounds for rear lights on my project car. Just mockups for now.
