Pete.
- Kent, UK
Yes a small granite one about 12 x 18"
Great, then you can scrape your cross slide and gib. If you want to borrow a scraper I'll send you one to use and a lapping disc to sharpen it. At half an inch out your 50:1 taper (probably) gib needs about 8-10 thou taken off but if you have the cross slide off already why not scrape it in a bit and improve the machine? At least run some checks to see if the cross slide is worn enough to warrant some work.
