gaz1
- westyorkshire
seen as i know nothing and have no idea
this is what you are dealing with
if your dealing with the top cap dont drill downwards on hammer use a grinder
you can drill sideways at an angle but you do not drill downwards you will crack it and if enough cracks it will fail and colapse
if you intend to upgrade where it stands and you can do then you can use a grinder to cut into the sides of it though is a mucky job a drill will crack and spread the bits all over the place in lumps this is the thing you dont want as you will then have to reline it
a grinder only spreads dust not chunks
so whilst your doing the cap fit a mushroom vent on it at the same time as renewing the cap
for other info mentioned
as goes for the cap one can be made easily with other info for building out of bricks
and yes concrete can be used as well
as goes for the lacking of punctuation thats the one thing i was never taught at school and to be honest at my age i really couldnt care less
to say i was only 3 points away from an o level the board wouldnt give me an o level and thats without the punctuations at exams and it was appealed so went through the board twice
for my spelling im still on top of that to say i dont use a program to sort it out even though i hardly use writing anymoreTbh I struggle with most of your posts due to the spelling, grammar and lack of punctuation.
