DAPPH
as dyslexik as I'm daft
I do believer Soay ( sp?) sheep make good grass & weed cutters for keeping the weeds down and you don't need to hoof trim them , a couple in the fenced off area with some shelter & water could see you have a tidy site and two lumps of meat for the freezer .Now I've got the camping trailer just about complete, I'm starting on some solar PV with battery storage. We don't want to put solar on the roof of the house. Apart from 22.5 degrees not being a good angle for solar efficiency up t'north, it's and old stone building, probably around1750s and it would look pig ugly. Plus the roof are sandstone "slates" called grey slate locally, so not ideal to attach stuff through.
The wife has identified a small piece of land that she doesn't want to cultivate. The good thing is that its bang on south facing. The bad bit is that its a bit of a pig to get to and its next to our boundary. its also a bit small, ideally I would have liked twice the area, but we have discussed this at length. It was the site of the old Calor tank and wouldn't be used for anything else, so its a good use of a rough bit of land.
I'm not going to discuss planning on the forum. This may prove difficult and I would rather French kiss Liz Truss than go through this with our planning department, let's just say its not permitted development and leave it at thatWe have told all the neighbours, and none have an issue as long as they are camouflaged a bit.
Here's the rough site survey. I'm going to do more detailed one once I get the strimmer out.
As per the text in the pics, I'm going for 3 rows of 4 panels. I need to make sure that I don't shade the panels behind so worked out the max angle I can tilt at is 41 degrees from the horizontal.
This assumes the panel is right on the floor, no gap, in reality there will be a bit. I'll rerun the calcs once I've done a better survey with a longer tape and somebody to help.
The height is important as I have promised the neighbours that they won't be much higher than our boundary wall. about 1.2m should be fine, the wife is thinking of adding a bit of trellis to make sure.
I'm thinking of making this a manual tilt system. So, I can adjust the angle of the dangle every couple of months to improve efficiency. The next thing was to understand the best angles at different time of the year.
The rule of thumb is the latitude minus 15 for summer and plus15 for winter, So between 38.7 and 68.7 degrees summer to winter.
A supposedly better method is during winter, multiply the latitude by 0.9 and then adding 29°. this gives 77.36 max angle. For summer, the tilt angle is calculated by multiplying the latitude by 0.9 and subtracting 23.5°. this gives 24.86 max angle so a much wider range, 23.5 to 77.36 degrees.
There are also various sites with calculators where you stick in your latitude or city. Interestingly, none of them gave the same result and they are different to the above. Here's the output of one of them, this one https://footprinthero.com/solar-panel-tilt-angle-calculator.
Optimal fixed angle
36.8° from horizontal
Your optimal tilt angles by season:
Spring: 36.8°
Summer: 21.8°
Fall: 36.8°
Winter: 51.8°
Your optimal tilt angles by month:
January: 46.8°
February: 41.8°
March: 36.8°
April: 31.8°
May: 26.8°
June: 21.8°
July: 26.8°
August: 31.8°
September: 36.8°
October: 41.8°
November: 46.8°
December: 51.8°
Using the above, my max angle of about 41 degrees means I would only be suboptimal for 3 months of the year. I'll do a bit more reading on this one, I don't like when stuff like this differs from the site to site
Given I can't get a machine in to level the land without taking down a dry stone wall, I'm going to concrete in some unistrut posts, or similar and build off of those. I have a dozen bags of postcrete that need using up, I may need a bit more postcrete but I'll dig nice deep holes so the structure will weather our winds ok.
Cheers
Andy
