Farside
Badly Welded Man
- Ireland
Somebody who doesn't have a clue what they cost.
Unfortunately I paid cashPaid on a card or App?
While you could make some, I found the chinese carbide ones pretty good, not that I have any proper machine to use them in, I used free hand and in the lathe for marking bars.The cutters are 3.17mm by minimum 10cm, if I remember. Although I have some steel rod I could turn then mill to that size, I have no idea what kind of steel it is. I’ve also never heat treated metal before, at 3.17mm diameter, would that be a problem heat treating?
Another question, what does STC21 mean in relevance to carbide cutter.
Thanks, but unfortunately the machine uses 10-11mm length cutters. They’ve put the fitting point at the top of the cutter holder.While you could make some, I found the chinese carbide ones pretty good, not that I have any proper machine to use them in, I used free hand and in the lathe for marking bars.
10pcs Tungsten Steel Engraving Bits,Blue Plating Engraving Milling Cutter Tool,CNC Carving Tool (20°*0.1),for Two-dimensional and Three-dimensional Engraving : Amazon.co.uk: DIY & Tools
10pcs Tungsten Steel Engraving Bits,Blue Plating Engraving Milling Cutter Tool,CNC Carving Tool (20°*0.1),for Two-dimensional and Three-dimensional Engraving : Amazon.co.uk: DIY & Toolswww.amazon.co.uk
This before going to work
Somebody who wants to collect it , in different clothes at a different time when they have a mode of transport handy?
Sucks to be them then, you snooze you lose.Somebody who wants to collect it , in different clothes at a different time when they have a mode of transport handy?
In this case, making up weight, plus it is in the original box.What’s the thrust bearing for?
