steveo3002
treated myself to the milwaukee ...is a 1/4" chuck easy to come by , seems alot of my bits are 1/4 shaft and a bit too snug to fit 6mm
my milwakee came with 2 different size colletstreated myself to the milwaukee ...is a 1/4" chuck easy to come by , seems alot of my bits are 1/4 shaft and a bit too snug to fit 6mm
yeah 6mm and 8mm ....1/4" tools are a bit snug for 6 and 8 doesnt close up enoughmy milwakee came with 2 different size collets
I was looking at this as I'm thinking of investing in M12 as I want the right angle grinder and 3/8" impact, there are 8mm to 1/4 adapters available, HERE, not used one myself. The 1/4" collet is available as a spare part, HERE, never used this company and £34.18 isn't cheap, £40 for the 6 and 8mm.treated myself to the milwaukee ...is a 1/4" chuck easy to come by , seems alot of my bits are 1/4 shaft and a bit too snug to fit 6mm
‘Kin hell!! A new grinder is only about £100….
u could always turn a 1/4" down if you have a latheyeah 6mm and 8mm ....1/4" tools are a bit snug for 6 and 8 doesnt close up enough
knocked a bit off a couple of them in the drill latheu could always turn a 1/4" down if you have a lathe
They’re a weird double collet. I’ll take a pic and show you what I mean….or make your own collets
You can get a Makita 18v LXT to Milwaukee M18 converter off a guy on eBay, if you don’t want to fork out for a new battery set. I haven’t tried mine yet as my plans on getting a portable bandsaw fell through.This is the thing, I often need it fairly compact where I'm at, but not sure what I will need where I'm going..might wait a while before dropping some cash
Annoyingly all my gear is makita, so would mean starting again with milwaukee.
www.abrasivesworld.co.uk
have to watch the rpm ...think the milwaukee are at least 10k min speed , although can use the trigger to slow it, dronco one is fine , other isntThere are 50mm cutting discs, for a 10mm diameter arbor:
Also 75mm, same 10mm bore:![]()
Abracs 50mm x 1.0mm x 10mm PHOENIX II METAL CUTTING DISCS *PK 1* PH05010FI | eBay
Find many great new & used options and get the best deals for Abracs 50mm x 1.0mm x 10mm PHOENIX II METAL CUTTING DISCS *PK 1* PH05010FI at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
And discs plus a mandrel/arbor, 10mm bore to 6mm collet:
A 10mm bore arbor for 1/4" collets:![]()
Dronco 76 mm x 1.2 mm cut off discs and mandrel 6 mm shaft to 10 mm hole | eBay
Find many great new & used options and get the best deals for Dronco 76 mm x 1.2 mm cut off discs and mandrel 6 mm shaft to 10 mm hole at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
RIGHT LINES Rescue Multi-Cutting Discs
Cut steel, brick, wood, cable & more with Right Lines Rescue Discs. Durable diamond edge. For grinders & saws. Long life. Wet or dry use.www.abrasivesworld.co.uk
