steveo3002
any suggestions on a roloc starter kit / affordble seller
Zoro with 20% discount code. Grab the holder and any bits you want. The little bristle ones are great for cleaning gasket surfaces etc.any suggestions on a roloc starter kit / affordble seller
where does one find the 20% off code pleaseZoro with 20% discount code. Grab the holder and any bits you want. The little bristle ones are great for cleaning gasket surfaces etc.
They come with a 6 and 8mm collet.Do they come with 1/4" or 6mm collet or possibly both . I have had issues with small routers using 1/4 and 6mm cutters any one had any issues with the die grinders .
There’s a thread in the forum somewhere. Just search zoro 20% off code.where does one find the 20% off code please
that's ok if you have a latheThey come with a 6 and 8mm collet.
Watch if you get a US spec one - the numbers are different, Google it, as they’ll have a 1/4” collet.
Even Milwaukee don’t know where they end up, apparently, but it’s no drama. I seem to get free pads with abrasives. Some have been 6mm and some 1/4” - I just turn the 1/4” ones down a bit.
Stick it in a drill and hit it with a file?that's ok if you have a lathe, please refrain from the remarks of How much I need one .
Cheers for the comparison pics gives a good idea on the sizes.M12 is great for little tight jobs the m18 eats metal
View attachment 356924 View attachment 356925 View attachment 356926 View attachment 356927 View attachment 356928
Depends how hard you're using it, I'm not hard on mineWith the 12v system say 6amp batteries what are people getting out of a battery, time wise, I know there are variables such as what bit, how much pressure etc but just an idea would be good.
Excuse me, but is that a workable combination - impact wrench on a torque multiplier?I have a 1/2” m12 impact that I sit and rattle truck wheels on and off with when at work. It won’t unscrew or do them up at full torque so I use my multiplier when out but I sit and hold them on till it won’t go any further
No I crack them using a small 1/2" ratchet then using my impact gun I get them all off, not on the multiplier. The impact does 450nm I think. They’re torqued to 650 which is only about 1/8th of a turn more than what my impact will do.Excuse me, but is that a workable combination - impact wrench on a torque multiplier?
E.g., are the gears in the multiplier impact-rated, and does the "slop" in the gear train actually transmit torque produced by rapid impacts, as opposed to steady pressure?
This is the thing, I often need it fairly compact where I'm at, but not sure what I will need where I'm going..might wait a while before dropping some cash
Annoyingly all my gear is makita, so would mean starting again with milwaukee.
