The_Yellow_Ardvark
- Going Away.
Dam.Oh I think it's been the law for quite some time now .![]()
There goes the chimey sweep side of MIS.
Yes.That 1/2oz weight is missing from a set my wife uses with our Avery scales.
I'm in the same boat with my Surf, but the body/suspension lift and taller tyres gives me enough headroom to sit up underneath and work on it in the rainI miss having a workshop unit at times like this.
Looks a bit precarious on that scissor jack! I've never read a good review on weld through primerHaven't fixed it, only cut away the rusted parts so far (still some left), now I am working on getting rid of all the remaining rust and grease before I start fitting replacement sheet metal. I need to buy some weld-thru primer as well.
I plan to paint it later with 2k epoxy. I think it's enough if you spray it thinly as a sealer. It should cure a lot quicker than brushing then, though that is an option on the inside of course.
Pics?My mates 1966 Lotus Elan.
Rebuilt engine in a completely rebuilt car - refusing to start. Initially turning over very slowly as though a flat battery, or duff starter. A jump from a decent battery than another car seemed to indicate it was the starter. He obtained a new starter - same problem. Compounded by the occasional total lock up, only sorted by removing the starter. Finally tracked down to being the clutch cover jamming against the starter gear - a quick session in the lathe sorted that . . .
Still refused to start . . .
He assured me the timing was pretty good, but impossible to set due to the electronic ignition. But after I give it a good twiddle around it coughed ., . . more twiddling and it ran, badly on three cylinders . . . the three I'd squired fuel down the throats of the carbs . . . He assured me it had fuel . . . proved it by taking top off one of the Webers More twiddling, until the leads were jammed under the manifold and it ran better and seemed to pick up onto four . . . but wouldn't come up much above idle. It then stuttered out . . .
Removed and refitted the dizzy in a better orientation.
Reassured me it had fuel . . . proved it by taking top off one of the Webers . . . empty . . . there was fuel in the tank as the pump was clicking away slowly in a "dampened" manner . . . I gave a tweak of the regulator he had fitted . . . well a good turn or so . . , and the pump speeded up then slowed back down as it actually pumped fuel . . .
Tried again - fired and ran a whole lot better. Further dizzy twiddling with the aid of a timing strobe, some carb balancing and adjustment of the idle screws . . . and we had a Lotus twin-cam that fired immediately on the key, settled to a smooth 850rpm idle, and picked up cleanly.
After a period of 2000rpm running and some clutch pedal pumping (he seem to suffer from stuck clutches - the one in his +2 does he same . . . I've never had one stick in 35 yrs, including cars living outside, with irregular use (or none at all through the lockdown etc) and it moved under it's power for the first time in 42 years![]()
This old book press.....
I wonder if it might be an old letter press from the days pre carbon paper, often found in legal or bank offices.
I know the feeling. Whenever I finish something all I need to do is look down and find something else to do - projects awaiting their turn everywhere! It’s bloody heavy I tell youI have one that's identical. It's actually a copy press for low volume printing. Mine was thrown out by Grayson Perry and is now languishing in the garden, in bits, until I get a Tuit
