I provided data that showed there was no difference. I provided this data you didn't.I lost interest in the lamp posts. I have data to show an led uses 40% less energy for the same luminance, as far as I'm concerned that's a 40% saving. I do not need to justify it further. I have access to every tier 1 manufacturer so choosing the correct one makes a difference
Storage has multiple uses, a common one we are seeing is a link between PV and EV charging. Might as well charge the battery for free to be used when the PV isn't producing
I have never seen a system that charged from the mains to use it at off peak times, for a commercial process they would just move production to the off peak time
It is quite simple, use the stored self generated electricity when needed rather than exporting back for the pointless feed in rates
Battery storage in your case makes sense - I am all for that.
Also I am not in any way questioning your abilities. You are very professional in what you do.
It's just that I question the whole renewables lark and the costs.
You mentioned before installing large industrial air source heat pumps. I looked the company up and was very pleasantly surprised to see they were British. I looked at the manufacturers data and they mentioned a 10% saving on electricity costs. I suppose that is better than nothing but it does seem a lot of work and outlay for fairly small gains.
