charlysays
- UK, Wales
There is a polyamide cured 2k clear coat from HMG paints called nisocoat 2 which could be worth a look, atleast a trial. I used the direct gloss from that range and it has dried very hard, thick and glossy with only two coats like a iso 2k. It is more prone to orange peel though than a proper 2k car paint.The bottom line is that 2k and especially clearcoat lacquers,, should only be used with an air fed mask.
ive previously used it with 3m mask and cartridge filters which are supposedlly effective...they arent.
i spent a week in bed struggling to breath and shivering like a wet dog after getting isocyanate poisoning, and refuse to use a facemask now unless its airfed (and through a filtered air supply).
Anyone doing any different is a bloody idiot......
I only used one set of abek2p3 filters on my respray. I did use an isocyanate free 2k though, I fully agree people shouldn't spray isocyanate paints with anything other than proper air fed. The filters were a bit harder to breathe through by the end but I still couldn't smell any solvent (and I was always careful to wear the mask even when just mixing etc so my nose would stay sensitive to the solvent smell).its not as expensive as you might think. air fed mask =£200, 3stage filter=£600
800 quid is a bit of an outlay, but if you look at how much you will spend on mask filters (which arent recommended anyway, either by 3m or HSE, and are gonna be causing yet more harm) its probably a few years worth.?
are your lungs worth £800?
or would you rather have breathing issues/asthma for the rest of your life?
Christ, i'm turning into my dad.......
So £35 for one set of filters for one respray (inside and engine bay not painted, just outer panels and shuts).
