@Rannsachair see told you - not a cloud in the sky. It's chucking it down here - never mind I can play in the garage all day
They don't have the fuel in them long enough to have any issues in that respectI've a mate who uses them, their only faults being they don't slice bread and make the tea. I'm a bit wary of plastic with modern, and future*, fuels, also I like the jerry can bayonet spout, and spouts for the above are difficult to get, or so he tells me.
*Hydrogen molecules are so small they diffuse through plastic. They are lighter than air so I reckon storing them in an inverted metal jerry can should be a goer.
We've got one of those. Sure it's MOD or USAF. We've had it 20 years I'd say.Lots of the boats use these plastic ones from Canada I think, they rate them very highly but probably cost about £100
I’ve got a couple of the 1l ones for the bike. Had a MOD one for a lot of years but lent it out and never got it back. The MOD ones were embossed with ‘Water’, or at least mine was.Lots of the boats use these plastic ones from Canada I think, they rate them very highly but probably cost about £100
Trust me you need a bigger mat !
Rubber might not be great if it gets oily. I was using a bit of duck board, over a big peice of old lino.
In some ways Im lucky having a tiny shed for the lathe, swarf cant go all that far.
stainless ones. They look good. Non sparking too I’d think
A Milwaunkee Fixtec grinder nut.
chuck it in the bin
Depends on the grade, but should be low discharge?Really???
I'd be careful - not much difference to mild steel with 304, and the assumption is that other grades are pretty similar. You wouldn't use them in environments needing to be spark free.Depends on the grade, but should be low discharge?
Canadian and US forces use them, they are excellent from what the fishermen say. Only issue they had was if they got hot the lids could be hard to turn with the expansion of the fuel but that was easily solved with a spanner cut from some 5mm aluminium.We've got one of those. Sure it's MOD or USAF. We've had it 20 years I'd say.
UK HSE did similar testing in the 90's - I had to refer to it in my first job for storage and mixing vessels for rather flammable adhesives and their even more rather explosive gases . .[BAM = Bundesamt für Materialprüfung => Federal Office for Materials Testing]
Authors: Thomas Grunewald
Co-authors: Rainer Grätz, L. Holländer
Document type: Lecture
Publication Form: Presentation
Language: German
Year of first publication: 2016
Synopsis:
Experimental investigations on grazing impacts with different types of stainless steel in explosive atmospheres, each consisting of hydrogen, acetylene, ethylene or propane with air, have shown that their ignition probability depends on both the type of fuel gas mixture and the level of kinetic impact energy. An influence of the chromium content in the stainless steel on the ignition probability by mechanically generated impacts could not be proven in the investigated range of chromium content, although an increasing chromium content actually lowers the oxidising ability of separated particles of increased temperature. Furthermore, other material properties such as thermal conductivity, specific heat capacity, density and hardness have an influence on the ignition probability of mechanical stainless steel impact events in hydrogen/air mixtures. As the thermal conductivity of the stainless steel increases, the ignition probability decreases. No influence could be proven for the specific heat capacity, density and hardness.
For impact processes, the standard EN 13463-1:2009 (DIN, 2009) specifies limits for the maximum kinetic impact energy below which the development of an effective ignition source can be assumed to be improbable. A distinction was made between impact processes with low-sparking metals, e.g. copper, brass, and impact processes with so-called "other materials". The limit values of these other materials result from BAM tests with unalloyed structural steel. In such impact processes, oxidation processes of individual particles with atmospheric oxygen are assumed, which ignite the gas mixture due to the high temperature rise.
However, in industrial applications such as the chemical industry, stainless steel is predominantly used instead of ferritic steel. In general, stainless steel highly alloyed with chromium is considered to have a lower spark probability in impact processes compared to ferritic steel, since the oxidation capacity of stainless steel particles decreases with increasing chromium content.
In the BAM impact tests, a decreasing oxidising capacity of the particles could be observed, but no decreasing ignition effectiveness of stainless steels with increasing chromium content.
FWIW (interessting that I never before asked this myself...)
Have a nice sunday all,
Carsten
DSG? Pics oleasesome big tooling for the dsg View attachment 349738
So far they are easily loosened, and I'd say able to put the same torque therough the handle that If normally expect to use on a pin spanner. I like them. There are pin spanner hooes, but a bigger size..Good plan. I bought two of them for two of my grinders. They stayed on the grinders for about two weeks before I went back to the original nuts. Most of the time I can undo the original nuts by grabbing the flap wheel or whatever. Occasionally I need to reach for the pin spanner. I thought the fixtec ones would be better, but they just mean I need to reach for a pair of pliers rather than the pin spanner. I think the fixtec ones are in the bottom of a drawer somewhere, never to see the light of day again.
DSG? Pics olease
