I don't think I was that much cheaper 30 years agoan empty wallet
For any broaching requirements please get in touch. I should think they will have paid themselves back in about 50 years.
I got mine a few days ago and have been using them on the 4.5" grinders. They work fine for the wee grinders but they can lock on tight and I have needed to turn them off with something in the bit you pull upright to get a wee bit extra leverage.A Milwaunkee Fixtec grinder nut.
I have a little terminal screwdriver (3mm? ish) that I use to get that little bit of leverage.I got mine a few days ago and have been using them on the 4.5" grinders. They work fine for the wee grinders but they can lock on tight and I have needed to turn them off with something in the bit you pull upright to get a wee bit extra leverage.
Much prefer the Bosch style but they are not much use for the smaller grinders so...
)Plastic?They are a bigger diameter than standard nut, loose a bit of reach on the cutting discs, but I think it will do nicely. Plastic handle is suspicious, I dont know if it will last.
Appears to work well.
I thought I had used some, clearly not.
problem solved, but I do prefer using a guard. The guard on cordless is a bit rubbish, I should make up a new one.Some copper pop rivets
a river at the bottom of the drive!
Upstream:
Downstream:
& a river at the bottom of the drive!
What's the other metal? Galvanized steel?
Are you meaning the flip up bit? Mine are steel I think.They are a bigger diameter than standard nut, loose a bit of reach on the cutting discs, but I think it will do nicely. Plastic handle is suspicious, I dont know if it will last.
I got one with my m18 grinder. Stupid flip up handle lasted a day!I got mine a few days ago and have been using them on the 4.5" grinders. They work fine for the wee grinders but they can lock on tight and I have needed to turn them off with something in the bit you pull upright to get a wee bit extra leverage.
I hate the DeWalt onesI got one with my m18 grinder. Stupid flip up handle lasted a day!
Best nuts I saw / used were the dewalt ones. Have a hex in for an allen key rather than a pin spanner.
Just replaced the one on the Flexvolt grinder with the Milwaukee.Copper!
How did I get that wrongAre you meaning the flip up bit? Mine are steel I think.
File test confirms it is steel. Seems solid enough looking at it again... Earlier it looked/felt plasticy.How did I get that wrongFile test confirms it is steel. Seems solid enough looking at it again... Earlier it looked/felt plasticy.
Erm...try a magnet?
