The_Yellow_Ardvark
- Going Away.
This old Vertical Steam engine came my way the other day.
At first I thought it was a;
German Bing Engine.
But during the cleaning I found a Made in England stamp.
Also, there was some damaged to the end cap. Some one had fitted a screw into the whistle boss. Rendering it scrap.
Of yes, it was not air tight eiether.
So the first job was to find a suitable whistle and boss in my Mamod spares and fit it.
Soft soldered into place.
The other issue is the fly wheel came off.
You can see the wear on the brass bush. The original plan was to make it steam tight and ask nicly for a friend for more lathe work.
The tin plate is so thin, it was collasping under the weight of the water in the boiler.
It runs on compressed air, but I think it's steams days are over.
Here I am de-rusting with citric acid. It was a strong mix and the red oxide was turning black very quickly.
), picked up some cobalt drills and helicoils, fitted a chuck to my mag drill, made a jig plate which I doweled and bolted to one the new discs.
