The numers are the manufcatures details and does not match anything in thr Bulb Bible, typical french. Even a manufacture, well the company who own them now have no clue what they mean.whats the diameter of the brass on the 12v, and are the locating pins both in the same place
and what are the numbers on it
) but it's now nice, strong and solid.View attachment 339556
LHS i a modern 6v standard bulb, easy to find.
RHS is the original, 12v and an odd size.
The manufacture does not even list a modern replacement. I am happy for it to run on a 6v lantern battery, but if I can locate a original bulb I would be pleased.
Didn't know you could buy those clips. Really annoying when they are broken. I will order some, thanks. My poor old B&D Workmate also now needs two new wooden top plates making since I laughingly forgot to set the cutting depth on my new circular saw a few months ago!Fixed my new to me Black and Decker Workmate, much better nick than my old one and came with loads of the orange clamp dogs. But all 4 of the leg clips were broken, so I get a new set from amazon for 10 quid ish and fit them this morning.
Old pale blue clips
New Black clips with new axles
All 4 done and clipping in and out nicely
Guy I sub for did that but went into the brand new pallet forks with the tct blade...Didn't know you could buy those clips. Really annoying when they are broken. I will order some, thanks. My poor old B&D Workmate also now needs two new wooden top plates making since I laughingly forgot to set the cutting depth on my new circular saw a few months ago!![]()
I'd be finding a nyloc, or the bottle of medium threadlock . . .(not Nyloc but used a Spring Washer with it).
Its now a flat washer with cut through it.Got some new shouldered bolts and compatible Nyloc nuts on order - the nut & spring washer was justa temp fix & to be able to test and prove all was wellI'd be finding a nyloc, or the bottle of medium threadlock . . .
Spring washersIts now a flat washer with cut through it.
