I've had an annoying vibration, kind of a drumming felt through the floor of my old LDV Convoy for a while, so been investigating.
Yesterday (as they are known to introduce vibration at certain road speeds) I had the propshaft off, checked out and replaced the donut on the centre bearing, re-assembled and checked/greased all the UJ's.
Didn't alter things appreciably.
So today I checked the front Shocks (as I knew the NS was getting on a bit, and I had a new one ready to go on).... jacked it up, removed the Front OS wheel and poked about. Turned out that the Lower Shock mounting bracket fixing bolt... was loose on the transverse beam axle! The thread on the Nyloc nut had failed (but was still on).
Pulled it all to bits, bunged on the new shock and refitted the Lower mount with a new UNF nut (luckily I had just one UNF nut in amongst things in the shed...& it was the right one (not Nyloc but used a Spring Washer with it).
Quick test drive showed all was well, and the ride also noticeably better
