Brad93
- Essex, United Kingdom
Not just us then hahaJam it up the spout of shultz-less shultz gun? I've moved all sorts of liquids with one of them.
There's another forum?Chap on another forum ....
It was second try with aluminium last Thurs,
I didnt get anywhere with brass yet, but should get a try this week.
Didn't think of that but not sure I want to be spraying diesel aroundJam it up the spout of shultz-less shultz gun? I've moved all sorts of liquids with one of them.
Not at today price’sDidn't think of that but not sure I want to be spraying diesel around![]()
True I intend to recycle any collected fuel in my workshop heaterNot at today price’s![]()
I have used a vacuum oil drainer to bleed loads of fuel systems with success , cheap as I already. had itOn TDCI engine you have to pull air through the low pressure side of the injection pump. All the hoses are plastic with moulded fittings so I doubt that would do the trick....
Whats the willow stick for?Brass is a funny one to cast.
I have had mixed success with it.
The best was when I used a green willow stick. Then cleaned the dross off, before pouring.
possibly this?Whats the willow stick for?
I'm off to find Germaine Greer and see if she's up for a bit of this
The acid, same as aspirin helps lifting the dross to the top. Makes it flows easier.Whats the willow stick for?
I'm glad I had the electric vacuum pump it was pulling for 5 minutes to clear the lift pump of airI have used a vacuum oil drainer to bleed loads of fuel systems with success , cheap as I already. had it
