I've considered in the past the practicality of doing them in the lathe. Need a method to accurately degree the spindle then lock it in place and run a tool back and forth. Essentially poor mans shaper.
Changewheels are handy for that.
I've already ground a tool and got the dividing head, but I was going to do it in the mill. However it involves making the quill lock and also being able to set a reliable zero, which my mill cannot currently do.I could measure the spline and grind a slotting tool to match it but I don't have any way of indexing a part to actually cut the spline.
They haven't got anything to suit. Can't press it on or you'd never be able to disassemble the leadscrew without cutting the end off
I think he meant press the spline sleeve into the gear or whatever it is you need it to drive.They haven't got anything to suit. Can't press it on or you'd never be able to disassemble the leadscrew without cutting the end off
It's on the hand wheels of the beaver mill Mate.I think he meant press the spline sleeve into the gear or whatever it is you need it to drive.
Beyond me and I don't have a rotary broach toolI'd make a wobble broach and broach them through. Can make a cutter in an hour or so.
