conor1n
- London/Ireland
So i've been playing around with various ideas for the switches over the past while. MSPaint has served me well as I can easily move stuff around.. here is the design along with some thoughts, reasoning behind positioning.
The design is an aluminium panel that will be cut and drilled then bolted (four corners) to some lightweight structure (TBD).
Small panel - To the right of the steering wheel, offering some secondary switches.
Large Panel - To the left of steering wheel (RHD), in front of the gear lever, with the appropriate clearance.
Any feedback welcome as this is a first pass.
Brownie points if you can find a use for this "REMOVE BEFORE FLIGHT" widget. Maybe I can just put it on the ignition key, meaning I need to remove before I leave the car... It's cool and IS needed
- Cabin is a momentary switch that I can press to temporarily light the cabin if I want to glance at something. The cabin switch on the other panel is latching.
- H. Light adjust will be the OEM headlight level adjustment (Never used it in any car, but it seems important lol)
- EPAS is the adjustment for the amount of assistance from the electronic power steering. This required finer adjustment and I am right handed so it's probably better to the right hand side of wheel.
- Door lock is a push button that will just lock the doors. It's there as OEM, so I may aswell keep it. Can be handy. Useful on the right so I can just slam it if needed - probably not totally track safe... but useful on city roads.
- Those toggle switches should be easy to switch with gloves and should offer solid tactile feedback.
- The led in the switch will be constant, whereas the indicator underneath will be on when in on position.
- This design should enable me to find the switch easily and also see if it's on/off at a glance.
- The buzzer will sound along with one of the following lights when one of the following conditions is met.
- NO ISOLATE - Door open and battery is not isolated
- KEY IGN - Door open and key still in ignition
- Hazzard is a push / pull switch so I can just easily push with my palm.
- MAIN will light up when battery is no longer isolated.
- IGNITION will light up when key is in and turned to ignition position. I have toyed with push button start but this will be fine and secure. I need to keep the key in car, near immobiliser receiver anyway.
- OBDII Diagnostic port is there until I find a better home for it. I was going to have it right hand side, but centre is better if I wanted to put a laptop on the passenger seat, or have a passenger operate something while there is a driver, without the cable needing to cross over the driver area.
and am only catching up now....
. I have one of those 'aggressive' nozzles but have been afraid/wary of using it on anything yet - but that is really impressive
that's gonna be some tow car! Commercial?
The following montage should explain where I ended up.. and you might then understand why it was a bit of a mental set back. Just as I thought I had finished the welding and ready to move to paint.
