eLuSiVeMiTe
I refer you to post #26making this far more difficult and complex than it needs to be for storage, and way of the regulations for a habitable room
see previous posts ?But it's not a habitable room, never intended to be, I've said so so why bring it up? The aim is a clean and tidy, well built storage platform with no impact on the lightweight, aged ceiling joists. At the same time clean the place up and up the insulation to a good degree.
theres a few things involved first as its classified as change of use from loft to liveableSo if you put a roof light in but there's no stairs it can still be deemed a loft conversion? Thought it needed proper stairs.
Can't see accessing liveable space by a loft ladder being very practical...
Mind you, with all this beds in sheds stuff that goes on!
You may wish to make these alterations to enhance the storage facilities availableI've said in black and white it's not a loft conversion. It's just a decent storage platform in the cold roof space.
I've also said exactly what it's for storing.
with what you found on that nowadays you could sue the ex sellerChrist @gaz1 that took some remembering!
New 7x2 joists etc and a steel to hold it all up properly
Bloody DIY Dave's![]()
fitting an apex point
your building an attic truss@gaz1 I think I get what you mean now. Mine lacks the 2 webs that go up to the ridge board / apex. The bits the red web runners are attached to?
View attachment 324556View attachment 324557
because your removing the other cross truses you need to strengthen in other areas
you need to build the triangle in the high point of the apex for support or spreading the load but you also need to do a lower one from the 2" beam to the roof truss again under the beam
thats why you can only remove the middle cross truss one to get materials into play but once you do you will need to get the apex point built quickly
this will strengthen your roof before you remove the other 2 cross trusses so you can board your floors
