Lol yup.Are we putting a few bits of chipboard in the loft for a few cardboard boxes and old suitcases or a loft conversion !the forum strikes again .
Screws are prone to sheering. That's why nails are specced.What's the thoughts on putting joist hangers in with screws rather than nails?
I'd prefer screws but have read they designed to be used with nails that are in fact stronger than screws.
Screws are obviously easier, quieter to fit, do less damage to ceilings etc.
What he means is we get 3 pages of convoluted solutions to an issue solved within the first few posts.What? What do you mean by "the forum strikes again"?
I've said in black and white it's not a loft conversion. It's just a decent storage platform in the cold roof space.
I've also said exactly what it's for storing.
3 pages
you seem to be well over thinking it
Relax a bit![]()
Sorry. Low ball estimate. 11 or 12 seems to be more likely.
just to note the storage is light weight not medium or heavy weightWhat? What do you mean by "the forum strikes again"?
Use decent screws and don’t overthink it … it’s only storage not a mezzanine floorWhat's the thoughts on putting joist hangers in with screws rather than nails?
You've just described my life exactly except I don't get to the pubThat was last night up the pub. For a brief couple of hours I can stop the head wheels from turning. Other than that it's one unfinished project after another really.
Simpson make hangars so ….I like these, reassuringly expensive!
Buy Simpson CSA Connector Screws 5.0mm x 40mm | CSA5,0X40
Simpson CSA connector screws are recommended for use when installing Simpson connectors into timber, in order to obtain the published load bearing capacities. The CSA connector screw has a torx driver for easy installation and features a conical shape underneath the screw head to help the screw...www.tcfixings.co.uk
if your wanting more than light weight
please fit wall to wall beams then a new floor inbetween
Wouldn't going counter to existing joists help spread the load over the whole structure better?Something like this maybe? Rafters and purlins etc removed from the drawing for clarity.
A couple of 150x50 (yellow) timber beams adjacent to but independent of the existing (purple) binders. These supported by joist hangers into the end walls. One worry I have is there is from the corner of the stack at the top of the picture to the binder face only nom. 96mm to get a hanger in and new beam.
Then new 150x50 joists (yellow again) across. Noggins of course etc.
The new joists supported by nom 100mm high blocks (blue) down to the existing wall plate (red). That'd cut the span down.
Thus nothing bears on the existing celing or binders. I'd have 1" clearance from the underside of the new (yellow) joists to the top of the existing ceiling joists.
