Ubique
- East Midlands
He buys it in from Germany and his name is Mateusz Poplewski, so.....It’s whether he will send it to Sardinia though!
If its a nasty environment metal workshop with dust grinding etc also lungs to add onto the list , not sure where on the priority list it would go thoEyes, fingers, toes. Protect in that order if you can't get it all at once.
ETA, this guy sells reasonable used workwear https://www.ebay.co.uk/str/healthandsafetyequipment?_trksid=p2047675.m3561.l2563
RespiratorIf its a nasty environment metal workshop with dust grinding etc also lungs to add onto the list , not sure where on the priority list it would go tho
Yes , no matter if they take the **** about it or call you wuss whatever. Apprentice wages are certainly not worth damaging your lungs for the rest of your lifeRespirator
True point , Would rather a little welding or grinding dust in my lungs than eyes I guess. Aside from asbestos which one fibre could ruin you that is but thats probably a little specific....but can withstand damage longer than fingers, toes & eyes, c.f. smoking
I'm not saying it's not important, if you're self-funding PPE it's probably lower down the list. I rarely use a respirator or face mask (except for Covid protection) but I did smoke Marlboro Red for 40 years....
I'm using FFp2 masksEwwww.... that's not good - could you use 'covid' masks as an interim measure until you can get something better?
Burnt up , with no undercut , strange ripple patternAnd how's the Mig welding looking ?
Yes you are right it should be in either short circuit or spray transfer dependant upon material thickness and joint geometryBurnt up , with no undercut , strange ripple pattern
I believe because I was experimenting various things all together.
Like torch tip to work distance variations,torch angles ,travel speeds.
I believe it should Go in spray or short circuit
Yes - grind off all the paint and crap first. The rule on steel pretty much is: First you grind, then you weld.The bucket ones are horizontal fillet welds
The ones on the concrete mixer are vertical downhill on thin rusty painted covered in concrete and zinc steel
Any advice to make them better?
only use one handHand held welding shields are for mugs! That's the first thing you need to change.
MIG puts down so much metal so fast that you need both hands to keep the torch steady.
