Hello everyone,
I'm at a loss: with the original four-post tool holder and a 12x12 cut-off steel holder, I'm about 5mm over center height!
I do not understand this. What is wrong?
As I showed a few days ago, when the turning steels from the pile got smaller, only one with a 5.7mm shank (IIRC) reached about the centerline without overshooting.
But that can't be the solution....
At the very beginning of this machine on this forum, user @Agroshield wrote something about recognizing different features of different versions/models in the pictures - What about that?
Any idea?
Carsten
I bought a 4 way toolpost supposedly for a ML7 & I have exactly the same issue as you - it sits too high! I have stuck with the original single tool holder for now but I plan on using the lathe to remove enough metal so that the carbide tooling I have will sit low enough.
When the bearings are clean and cooled down in your hand, you should not try to turn them, as they are now absolutely dry and without any lubrication.
