Hood
- Carnoustie, Scotland
You say that in jest but just take a minute and think about the recent decisions that have been made by those in power.And must all be electric by 2035...
I photo'd the shaft a few minutes ago and also checked the pin holes..Not sure about the bearings but you need a taper reamer to finish off the holes for the taper pins.
Got my ears bent in 2015 for a £1200 pure sine wave genuine 2kw Honda genny , delivered & run up for the first time for 1/2 hr on 15 June 2015 It's been used numerous time off grid and as home back up . Wife now says I'm glad you brought the genny . Sat here at the desk I've just peeked into the log book , it's been run 9 times & has 13 hrs. run time in the log book .Exactly, price will probably be up for a while so will wait and see what happens.
, to fully recharge the battery using the faithful de-sulphating charger ,bclean and grease the terminals with Vaseline then give it a 20 min warm up & load test runHowwwwwwwwwwwwwwwwwwwwwwwwwwwwwww muchThere are portable lithium back up units already available, can be charged with mains, solar, 12v ect. A few sparks I know use them for dis board changes so there is some power available, also a couple of boat owners I know have them. The one below is 200w but bigger capacity ones are available!
Eldest twins been busy today!View attachment 321312
I've used internal UPVC window cill skinning plastic about 9 inches wide by 10 mm thick left over from a job done years previously , screwed in at the longest side edge and pushed out at the bottom with a strip of wood to give reclining " L " shaped shelf some four feet long .A bit of 2mm sheet to go on chip guard. Vice bender was at its limit, and needs modifying so that it doesnt constantly drop down. Bigger vice wouldnt help as the design is poo and cast iron is not easily be improved...
Then trying to plan a rack for boring bar holders, to go on side of tool cabinet, its going to need a bigger bit if sheet. I might use 1.2mm instead, but thats hidden back of garage.
I don't understand. I have one livecenter that came with the lathe. What I've made is even cheaper and more simple?The chuck has a morse taper comes with the lathe and can be used with any of these home made live centre supports of different diameters , whereas you need several different diameters of tube support ing live centres with morse tapers at a greater expense
Great idea,he’s even got the canoe ready.Moat?
I have a fixed & a moving steady that needs modifying to fit my lathe ... They will have to wait till I have got the back shaft back in action so I can use a fly cutter to get the precision base plate of the fixed steady made & built up to the correct height .I don't understand. I have one livecenter that came with the lathe. What I've made is even cheaper and more simple?
It is a cap that fits on the centertip, approxemately 4mm wall OD 32mm.
If I make one more of say 100mm I think I can support all sizes I need.
Would love to see some pictures, get your mate to upload some.Mate works at a hospital and is an electronics whizz and he got lots of lead acid back up batteries from work, they gave them to him as its cheaper than paying to dispose of them.
He built his own system above his consumer unit which consists of a rack of intelligent chargers and 12 batteries and they are on an intelligent charge while mains power is on so are always fully charged, if power goes out it switches on a home built LED light in his consumer unit and several more strategically placed (his words) lights around his home which turn on and are powered by some of these 7 and 10 amp batteries, the 4amp batteries can be removed and power more home built lanterns which he can move around his home to light specific areas.
He obtained a large lead acid battery pack of over 2000 amps and placed it in his shed and connected this to a medium invertor and can switch his boiler over to this to run the electrics for his gas central heating for several hours.
He also has a small invertor suitcase whisper generator to top all these up if necessary and in the event of a power outage he can switch to these and have light and heat in his house and the last power cut they had saw his house lit up like a Christmas tree, and heated.
I got a handful of batteries from a hospital, they're "Standby" batteries and not made to be discharged more than a couple of times a year. I actually had similar plans for them but after five years on a trickle charger they're pretty crap, and now they're my problem to dispose of.Mate works at a hospital and is an electronics whizz and he got lots of lead acid back up batteries from work, they gave them to him as its cheaper than paying to dispose of them.
