Munkul
- Cumbria
Metric mics are fine, you can eyeball 0.005mm resolution between graduations which is more than you'll ever need to work to... 0.1mm taper is good enough if you can't get it any better. Its as likely to be wear in the ways as much as anything else.
0.005mm is just under 2 tenths in bananas, that's well enough accuracy for anything other than watch making!
