Or worseoooh aaah ouch eeee as the blue hot chips fall down your collar![]()
I paid for all 7.5HP of the triumph got to attempt to use themOr worse![]()
Indeed so.I paid for all 7.5HP of the triumph got to attempt to use them![]()
Wait until you try the ceramic tips Fizzy.
Nothing good about them unless you're trying to cut hardened stuff I believe...What is special about these?
can you explain the two nuts trick ,no pun intendedMaking a die holder at the moment for a training piece
The lecturer liked my two nuts together trick for how to sharpen drill bits that works on big or small ones just as good
Still getting better at the sharpening as I go but Intresting doing it on 24mm drills not the 10mm or so I'm used to doing
So does carbide if you are doing hard steel.Ceramics spray red hot chips
thats perfect , thanksSure , quite simply just put two nuts or bolts and any hex together to get your rough angle for grinding a drill bit in
So when I am grinding and think the grind on the bit is quite hold up to two nuts and can hold up to a light to see if the grind if flat and the same on both sides at the 120° angle that you want for standard drilling
Just keeps you right as you sharpen probably not done in million pound CNC machine shops lol but works for the home shop learning to sharpen drills and if you don't enough you won't need the nuts anymore
The hot chips problem, I have found two solutions!
External turning in reverse with a left handed holder or RH bar. The chips go away from you. 7mm off diameter was no problem, that is a big cut for this lathe!
These single edge chip breaker inserts, I like them as they break chips 100x better than normal. Instead of high velocity small C's, or high velocity curls, or stringers, you get thick, slow C's, or tight curlers (a bit lile a parting swarf wheel). Did not get burned, did not need the cardboard guards!
Problem is availability. I only know one shop with a few left, on clearance. I would have posted this before, but first I wanted to buy plenty for myself
I think KNUX style inserts are similar? Have not used them but only turning inserts I know, that are normally single edge.
What?! That's crazy talk. None of the above is correct, apart from "For home use they are more limited". You wouldn't choose them for cutting plasma-cut steel unless in a very specialised application.Great for harder steels and rough cutting of flame cut or plasma cut steels and they take large amounts of material in one go, basically they are aimed more towards production work where speed is important.
For home use they are more limited unless you machine a lot of rough cut stuff and stand more abuse then tungsten. It comes down to your use and cost, can you justify spending the extra by increasing your speed or improved longevity.
Cannot wait to see the pictures, bet they are awesome !Its not crazy at all and you certainly don't know what you are talking about to how about trying some, they work on all manner of things, often better than carbide, on other things they are worse so just another nice addition to have for when they are needed for the type of lathe work I sometimes do.
so just a pair of stepped radius grooves to see if it works.
