bert
- Wiltshire, England
Yes there are holes in the keels now after wire wheeling nut the deck was the main culprit and that's now welded up.No chance the hull's pinholed?![]()
Fill it with water afterwards, and see if any leaks out........No expert, but if you cannot gain accesss to the rear of any weld areas how do you propose to make sure all the welds done from one side only are perfect?
Now thats a man with ferrous spheres ,,,, even I wouldnt try that and Im game for most things , I can certainly see the theory but Id like to see the pictures just the same.The hull needs drying out thoroughly, and the old paint will need to be stripped off anyway, come what may.
At this point it's time to start gathering plenty of logs and some kindling, and get a proper fire going under the vessel.
Carefully monitored, it could save a lot of work, and banish dampness from the dank and mildewed interior fixtures and fittings, as well as removing exterior paint and antifouling down to the bare metal.
Definitely check the insurance small-print though; is it 3rd party only, or fully comp? Just in case.
(No Health and Safety risk-assessors need to attend; everything is fine, officer. Yes it is late for Guy Fawkes night, and no it's not a Viking funeral ha ha, just burning off a bit of paint.)
No chance of sand blasting it?I think I'll stick to grinders and dehumidifiers for now![]()
yea with a cheap pot and a 14cfm compNo chance of sand blasting it?
.... and a little patienceyea with a cheap pot and a 14cfm comp![]()
a guy i know wanted his new narrow boat hull blasting. had his own road tow comp so i hired him my airfed helmet and the pot and he did his own. i scored 80 quid and he had it for a weekBest thing I did some years ago - pay a man with the right gear to come along and blast my rusty objects - took him longer to set up his gear than to do it. If you worked out pounds per minute working, including his set up and dismantling time, he was on quite some rate! But work out the time and effort saved on my part, and the quality of the job being so much better than I could have achieved with the gear I had, it was worth every penny.
I think you need alternative quotes! Guy who did my stuff usually blasted buildings.I got quoted £12k to have below the Waterline blasted.
I don't think they let anyone else on site, I'd need to check but for that money I'd be buying my own road compressor and set up.I think you need alternative quotes! Guy who did my stuff usually blasted buildings.
I know the joy of what pien ball hammer hitting the side of a 120+ year old hull sounds like!!If you can make a dent with a ball pein hammer lightly held, but swung at arm's length, it is a cause for concern because that's the kind of impact which can often be suffered by hitting floating tree-trunks and so on.
Only just seen this and read the post. You mentioned your ultrasound is working intermittently. That could well be down to internal corrosion affecting the readings. Regarding repair, definitely cut the affected area out and weld in new steel. Overplating although very common in boats is not a good thing. It causes more issues than it cures.I recall that @spaffmonkey welds up steel boats for a living.
I agree with totally drying out, but there are far better ways to do it.The hull needs drying out thoroughly, and the old paint will need to be stripped off anyway, come what may.
