I'd not trust my welding abilities where the requirements are "not to let in water or sink"
from a guess the hulls original thickness will be 4-5mm then 3.2 will do.So 6013 rods but what size? My machine can take 3.2's but not for very long.
my favorite saying when people asked me to do an inch of weld. for every inch you see there is 6 to doJust remember that there will be at least five times as much to do as you expect![]()
On a good daymy favorite saying when people asked me to do an inch of weld. for every inch you see there is 6 to do![]()
..'The dutch do build nice steel boats ,, they only start to go down hill once they get wet..'
I used to use one of the big white oil drainers to do the engine beds in my boat and it did very well. May not suit your job if theres flakes or the likes floating about , but great on low solids water / oil mixes , and cheap ish and needs no electric .No expert, but if you cannot gain accesss to the rear of any weld areas how do you propose to make sure all the welds done from one side only are perfect?
The wet/dry shop vacs are quite good, we emptied a boats bilge of oily/watery mess the other day with one, I was impressed as had never used one before, so i am thinking you could mi=x up some soapy water and clean the bilges then vac the mess out?
Yep take no risks there ..... Newspaper >P40 > undersealI'd not trust my welding abilities where the requirements are "not to let in water or sink"
P40 that’s posh, what’s wrong with pollyfilla, I mean it’s waterproof once you cover it in emulsion.Yep take no risks there ..... Newspaper >P40 > underseal
this time only about 70l which must bring the total to nearly 500l or water I've removed from the hull. The deck must have been letting water in for years. I've stuck the biggest dehumidifier I've got down there and it's showing 99% humidity.The deck must have been letting water in for years.
