This has to be one of the most fiddly pieces of gear I've ever had to mend,
Yes we will unless.......We will never mention this again![]()
Your fate is sealed. You should know by now, nothing seems to escape the Vark.Yes we will unless.......
A box of tissues.
Wife asked me to fix this. Couldn't find the stapler, so used the next best option.
Won't tell you what she said.
More repairs on the giant travelling saw,replacement of m16 bolts that are too long for the space in between the flanges of the channel(4”),so notches we’re cut.View attachment 317863
Overseas the tapered are known as "hillside" washers.Some proper tapered shims instead of a stack of washers would work a fair bit better in that taper flange I beam.
Iirc that washer is 5 degrees which matches the channel,the flat washer is to stop the spring washer opening apart,which is what had happened to the previous attemptsSome proper tapered shims instead of a stack of washers would work a fair bit better in that taper flange I beam.
Throw the spring washer - its just another flat washer when tightened - and the crappy wire ones simply open - as you found already. You've defeated any theoretical ability of it to stop the bolt coming loose with the flat washer anyway. If you want it to stay done up against vibration, a nordlock washer under the bolt head without that additional flat washer, and another under the nut (no flat washer there either) - if its going into a nut plate or captive nut that can't rotate, just the nordlock under the head will do. The tapered washer you already have in there shouldn't be able to rotate once tight and defeat them.Iirc that washer is 5 degrees which matches the channel,the flat washer is to stop the spring washer opening apart,which is what had happened to the previous attempts.
Thanks for the offer,I’ll check my stock and if low,will pm you.I may have a stack of proper, galvanised, taper washers here. Do you want me to look?
